It used to be alright, but we stopped using the camera for a while, then we recently just took it out and took a few pictures with it, and we want to upload them onto the computer - but when we connect the camera via the USB cord there's no reaction.
The USB port works, and the USB cord works with my other utilities eg. mp4...
Could it be that the USB port on the camera's damaged?
The camera works fine, but when I connect to my computer(mac, iphoto) via USB, the display mode powers down in 2 seconds. When not connected, the display mode is fine. Because of this, I can not transfer pix to my computer. Thoughts?The camera works fine, but when I connect to my computer(mac, iphoto) via USB, the display mode powers down in 2 seconds. When not connected, the display mode is fine. Because of this, I can not transfer pix to my computer. Thoughts?
You can't post conmments that contain an email address.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nothing is wrong. The file names of the recent pictures probably duplicate those of your old pictures. Your computer is probably caching the images associated with those names until you double-click on them.
Since you declined to specify the type of computer and the software you're using, I'm afraid I can't tell you how to clear the cache. I also assume you're not really connecting your 35mm SLR camera to your computer.
Try using a different USB cable. The connections between cameras and computers usually are problematic. A card reader will allow you to download the pictures from the SD card, without problems and saving your camera's battery power supply
Any way I can fix it?
