Question about Saeco Stratos Coffee Maker, Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
Machine wont make coffeee message says ventilate?
  • Saeco Master
  • 1,711 Answers
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Posted on Jun 06, 2010
  • Rose Trupkovic Apr 19, 2014
    What if hot water button doesn't work it just stays on ventilate
SOURCE:
My Gaggia syncrony digital has just stopped working....the coffeee is still being ground but there is no coffeee coming out....no water seems to be getting through. Any ideas?
There is one of 2 things going on either the machine needs to be descaled and or the brew unit screen is blocked. Remove the brew unit from machine and check screen below the red o-ring.
Aug 04, 2011 | Gaggia Syncrony Compact Coffee...
We are getting a "ventilate"
Hi.
When you get ventilate the machine functions are locked. Try following the indications here:The following procedure works when you get the ventilate error: The Ventilate sign can...
Regards.
Ginko
Mar 03, 2011 | Gaggia Titanium Espresso Machine
Ventilate problem on gaggia titanium coffee
May 27, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
What do you do about the ventilate message
Ventilate is the same as priming the machine open the hot water valve to purge the hydrallic system.
Jan 24, 2010 | Saeco Magic Comfort Plus Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
New Royal espresso machine
Run hot water cycle to ventilate machine.
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Stratos Coffee Maker, Espresso Machine Logo
739 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
