Baby Gear Logo
Posted on Apr 04, 2008
Baby car seat
took my childs car seat apart to clean it and now i can't reme ber just exactly how the straps go it is a 22-756-LRS.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1391
Points
17
Here is the link you need
http://www.eddiebauer.djgusa.com/usa/eng/DJGFiles/ProductDocuments/43583340D.pdf
How do you adjust straps on a baby car seat?
Graco SnugRide 35 : Adjusting Harness Straps - YouTube
? 6:41
https://www.youtube.com/watch?v=vl_JSaEuu0U
Jun 23, 2012 - Uploaded by Baby Car Seat Installers
This video shows how to adjust harness straps for the Graco ...Graco SnugRide 35 : Adjusting Harness Straps. Baby Car SeatInstallers.
Britax B-Safe: Adjust Car Seat Harness Straps - YouTube
? 3:12
https://www.youtube.com/watch?v=XGHnSLXRqq8
Mar 2, 2014 - Uploaded by Baby Car Seat Installers
We teach you step by step on how to move the harness strapshigher as your child grows. This video is for ...
1helpful
3answers
Rethread car seat straps
Here is cosco website , input your model number in the box and you will be able to download step by step illustrated instructions for your model.
1helpful
Need instuction on how to reassemble safety straps on cosco car seat. I took apart to wash seat cover and don't remember how to reassemble
1. Find the same seat at your local store and take photos with your phone.
The position of the harness (slots in the plastic shell) is dependent on the height of your child.
2. Contact the manufacturer for detailed instructions
3. Find a certified Child Passenger Safety Technician or Instructor at safercar.gov.
I took apart the car seat for the eddie bauer adventurer travel system and trying to put it back together. Please help.
Contact a local Child Passenger Safety Technician (or equivalent if you are not in the USA) for help. www.nhtsa.gov
The seat MUST be rethreaded correctly for the safety of your child. Do not guess!
I HAVE A CAR SEAT THAT I TOOK APART IN ORDER TO WASH THE CUSHIONS BUT NOW I DONT KNOW HOW TO PUT THE STRAPS BACK TOGETHER
There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: http://www.coscojuvenile.com/usa/eng/Instructions The pages in the back normally discuss reassembly after cleaning.
4helpful
I took the straps off my Brevi Childs car seat to wash and can't get them back on!
Hi I am looking to buy a Brevi Universal car seat cover and the straps as well what web site should i be looking on???
19helpful
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
2helpful
Having trouble with straps in car seat
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps.
Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat.
The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it
doesn't twist, either.
There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side.
Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.)
One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
I need to put the straps back in seat
When I was doing research on your problem, I came across this recall. Please read and see if it relates to your product. RECALL ID# 66785 - CHILD SEAT Recall Date: July 28, 1993 Model Affected: AUTOMATE Recall Summary: THE TONGUE OF THE BUCKLE ASSEMBLY CAN CORRODE. THIS DOES NOT COMPLY WITH FMVSS 213, "CHILD RESTRAINT SYSTEMS." ALSO, THE LABEL WITH USE AND SAFETY INSTRUCTIONS IS MISSING FROM THE PLAYSKOOL MODEL. Consequences: BUCKLE ASSEMBLY CORROSION COULD AFFECT THE SAFETYPERFORMANCE OF THE CHILD RESTRAINT. THE MISSING LABEL MAY CAUSE IMPROPER USEOF THE CHILD SAFETY SEAT. Remedy: KOLCRAFT WILL PROVIDE OWNERS WITH A FREE REPLACEMENT HARNESS ASSEMBLY AND INSTALLATION INSTRUCTIONS. OWNERS OF THE AFFECTED CHILD SEATS SHOULD CALL KOLCRAFT TOLL-FREE AT 1-800-453-7673, TO OBTAIN A NEW REPLACEMENT HARNESS ASSEMBLY. Notes: KOLCRAFT ENTERPRISES, INC. Potential Car Seats Affected: 307017
15helpful
2answers
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 • Baby Gear
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
