Canon Printer Error Code 6000 refers to something in the printer that is interfering with carriage flow. In any case, I was able to find the problem: a piece of ripped paper on the left side of the printer. Hard to get but is possible. The printer works again! But Sometimes some software problem causes this. Foreign objects, such as dust spores, bits of paper, pin, stickers, or other objects, block the correct opening of the paper feed tray. Due to the jam, the printer shows an error of 6000.
Causes Canon Printer Error 6000:-
It happens primarily where the printer's paper feed tray stops it from opening when something is blocked in it, normally dust particles or bits of paper.
This error code can also occur when the tray is not properly fitted to the printer.
This error can also arise when we attempt to send several print commands at a single time.
It can even occur on the computer when a printer is surrounded by a number of papers.
Line feed is either scratched or coated.
When any flaw happens in the sensor device or in-line feed slit.
Solution is here - Canon Printer Error Code 6000
I Hope this will Help you.
Are you lagging with canon printer error code 6000? Well, no need to look further for the solution of this error. We have written a comprehensive guided article on how to fix this issue. You can go through that blog and just by following few simple steps you can fix this error easily.
In case if you are looking for an expert assistance you can connect with us at +1-888-633-7151 Canon Printer Tech Support Number and we will assist an expert she will help you one to one to fix this issue.
Follow the link to read the blog - https://www.printererrorsupport.com/blog/how-to-fix-canon-printer-error-code-6000/
Tips to fix this error code on your Canon printer:
? Turn off your Canon printer for some time, wait for at least 10 minutes and then restart your printer by turning it on
? Check whether the paper tray is set correctly or not. If any foreign substance is obstructing the path of printing, you should remove that object
? Verify whether any tiny object or simply a torn piece of paper is present in your Canon printer. If so, remove it gently to experience smooth printing
? Try to clean other components of your printer machine which includes the print head or the encoder strip.
If you get stuck then do visit us: canon printer error code 6000
Toll-Free No: +1-888-633-7151
Error 6000 refers to an obstruction in the printer. Take a flashllight and see what is in the way. Really take a look! It took me a few minutes to figure it out. Watch my experience:
