When i try to click on like, it wont let me.When i click on view all comments it wont let me. White screen on both. On bottem it says modify and something else.
Please..if you do not have adobe flash player in your pc.. download this software and install it now.... If you are using facebook frequently.. please update your browser to the latest version of mozilla firefox. facebook is easy to access using that browser...
Let me know it that did not help you... Much appreciated if you rate this help.. thanks
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
sometimes the router needs to have the mac address of wireless devices on a list of accepted devices
you could have to input a WEP password while connecting to the router, depending on your router, it may be located on the bottem of the router, box it can in, or one you created from the routers settings screen, check you user manual for more details
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
elaff + SHARKmark + arun - your phone sounds like you are having battery issues you can replace the battery with a new one and see if that fixes the problem if not take the phone and ahve it reflash or replaced the flexcable.
GUEST - the phone needs to repaired the flexcable also need replacing
hi their is only i thing you can try yourself as if it is anything else it probably requires soldering and new parts. on the bottom screen their will be a ribbon its really thin and will clip onto the board from the screen the same with the top one the only thing you can do yourself is check that the ribbon hasnt come out of the housing and is causing a bad conection it might have a sticky bit of thin tape over the conector this holds the ribbon in and prevents it from moving out of the connector you will need to check both ends of this. try pushing the ribbon back into the conector without removing the tape and see if this solves the problem. If you can see the clips holding the ribbon into the connector you can undo these should just clip open the remove the ribbon and put it back in again the push clips back to lock position. If this dont solve your problem then the chances are you need the screen replacing but your problem is the same with mobile phoned and removing the ribbon and putting it back in again usually solves this problem let me know how you get on ok
It could be the graphics driver or the monitor.
If you had a screen saver on or had the notebook set to hibernate, turn them all off first.
If you are able to view via vga port then it could be a screen problem as the driver for graphics probably would give a problem on the vga also but it's worth trying firstly a system restore in case windows has updated the driver to a generic one, which can cause prioblems.
What is unusual is you have to set your desktop on the notebook to allow an extended view to your external monitor or a dual view, but your allows it automatically, normally this would have to be done from your notebook desktop view.
If no change try to uninstall the graphics adapter.
Go to my computer, right click>properties>hardware tab>device manager and in the next window look down the hardware list to graphics adapter, click '+' sign and your adapter should be there, so right click and uninstall, restart pc and try again
