Washing Machines Logo
Posted on May 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine not spinning.model mw511 serial no bra 803683. machine sounds like it is spinning but the clothes come out dripping wet, water drains out but the machine doesn't spin clothes????
Anonymous
Level 3:
  • Washing Mach... Master 43,501 Answers
  • Posted on May 22, 2010
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10835441
Points
101584
If you are having a problem with your top load washer then check out this tip...
Washing Machinewashing machine not spinning.model mw511 serial no - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washiwashing machine not spinning.model mw511 serial no - 2_bing.gif2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
I have a may tag Neptune washer model # mah4000aww. When I spin the tub it sounds like there is still water in the washer. Clothes are coming out very wet. Rubber drain is off and little water cameout
When a washing machine drum is removed from the tub after it has been in service for a while a number of objects are often discovered - bra wires, buttons, underwear, coins...
It is possible one or more such items is partially blocking the drain inside the tub.
1helpful
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
Why is my maytag Neptune Model no# MAH5500AWW spinning very slow and not draining water out?
Complete drain must occur before spin. A no drain situation would be an actual full pool of water seen in the bottom of the machine if all the cloths were removed, sounds like you are experiencing a spin enable switch failure, which mainly prevents final high speed spin leaving the cloths dripping wet. The spin enable switch contacts become tarnished/corroded over time resulting in poor connection. If the door lock light comes on than your door lock wax motor is working. The spin enable switch is the last switch to the right in the door lock unit where the light bulb is. Part# is 22002162. If there is an actual pool of water in the bottom of the machine as if you simply removed the cloths from the unit but left the wash water, than you should look first look to your drain pump for failure, or obstruction of foreign objects, or excess lint in the pump. Pleazer Appliance...
74bd738b-53cb-465a-99c1-ba55e2189ba2.jpg 5e1e4646-e2e3-4e7c-afc7-7a0e188e6cf0.jpg
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
1helpful
Clothes are dripping wet when I take them out of the washer?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Irt sounds as if your pump is somewhat blocked.
See the following for how to remove the cabinet and check the pump for blockage and/or a problem between the pump and motor.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=2edbaee16223b0927cee89fcc394964e
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
4helpful
2answers
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
1helpful
Clothes remain dripping wet after the wash cycle is complete.
I assume you have removed the lint filter at the bottom of the machine and cleaned it out to make sure the pump is not stalled on a 1 pence or bra clip. Can you hear the motor start to spin? If not its probably because the water level switch is gunged up at the bottom of its rubber tube where it comes from the drum. Remove the top of the machine and locate the pressure switch - usually a round black or white device about 80 to 100mm across with a rubber pipe on a small spout 8mm diameter. Take the pipe clip off using pliers to compress it and move it back down the pipe. Remove the pipe and blow hard down the pipe to try and clear the blockage - you will hear bubbles blowing in the bottom of the drum water. Also you could very very gently blow into the switch stub pipe and listen for it changing over - clicks usually twice each way - blow - two clicks, release - two clicks. Restore swtch pipe and try the machine again. Good luck.
Top Washing Machines Experts
john h
