Direct tv remote codes supersonic tv
Ask the remote code search engine. They will figure it out for you.
I can help you with your Supersonic TV & DirecTV remote control.
I do not see a code listing for Supersonic TVs in the DirecTV Remote Control Manual.
But don't give up; many manufacturers reuse remote control codes. I recommend performing a DirecTV Remote Control Code
Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List
Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
Search
Onscreen Setup
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
