Hiya. Pump is growling after wash cycle. It won't switch off except at mains. When turned on again it says 8 mins left, then C3 alert appears.
I had a new heating element put in before Xmas. The Dish Washer is 7 years old, in pristine condition internally, and last repair cost £114.
Maybe it's time for a new one unless a simple logical answer above problems?
Any suggestions? & Thanks
SOURCE: aeg sensorlogic 50700 first showed c2 message; we
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
My problem is the same
