The water is not draining out after the wash cycle is finished
Typically this problem is caused by a relay selonoid located at the output hose of the water pump. You will need to remove enough of the outside cover to see the water pump. The valve that is connected to the selonoid will be visible - and you can place the machine on the drain portion of the wash cycle and you will see that the selonoid does not operate. It can be removed (2 or 3 screws) - and a new one installed. That should cure your issue.
Ironically I just had this happen with my dishwasher.. The lever that is operated by the "drain" selonoid would not move. I hand operated it to the "other" position and turned on the dishwasher - sure enough the water came out into the sink drain. Confirmed that the selonoid was bad.....replaced it and problem solved (Hotpoint model)
