My router Linksys wrt120n was purchased before System 7. Firmware version 1.0.0. My new System 7 does not auto reconnect at times. Wanted to upgrade Router firmware to V1.0.1. Instructions say to use the .bin file but a ,bin is not in the download. Other documents refer to a .img file but this is also not downloaded? Not sure what is wrong. Linksys is of little help
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
