I have a wood's "all fridge". It's about 5-6 yrs old and I am getting water in the bottom, underneath the crisper drawers. When it gets too full it leaks out through the door leaving a big puddle on the floor in front. I looked at the manual but there was no mention of a problem like this.
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
Take out the crisper drawers and the 2 shelves above it. You will need to remove the 4 screws that are holding the back panel on, don't pull it too hard the grounding wire is attached to the panel. I found that half the "putty" that was put around the wiring/freeon hole had fallen off and was in the drainage trough. It had run the the drainage tube and blocked it so the water had no where to go except under the crisper drawers and out the front of the fridge. Worked for me, hope it works for you. Other than this slight problem, I love my Woods all fridge, Andrea
