Cameras Logo
Posted on May 21, 2010
Hdc-570as wont switch on - Hitachi Cameras
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
432
Points
Ive just had the same problem and solved it first you have to plug it into the pc with the usb then just before it goes onto the menu for pc,bridge,and pc camera pull the lead out quickly as you can. the camera will stay on to allow you to the next step
go into the menu and click next menu and go to fr. no. reset. and click execute then go back to the second menu and go to sys. reset and click it the click execute.
once this is done turn the camera off wait 10 seconds then hold down the power button until it turns on
done
if you have trouble let me know and il guild you through it slowly
  • Ruthie Kays
    Ruthie Kays Apr 26, 2016
    i cant do it just turns off the second i pull the lead out
Zoom lens won't open when i switch on
  • check if the batteries are fully charged.
  • try resetting the camera.
  • zooming motor has gone bad. have it replaced.
HDC system fault
Take vehicle to local auto electrician. Have them inspect the intire harness for a short. Check the wheel sensors. Check the HDC switch located on the underside of the gearbox.
2helpful
HDC Inactive message
hi today i was driving my land rover 04 plate parked up at a shop and when i got back in to start it the engine took a while to fire up i then drove it home and turned it off when i got there now it wont start although the engine has enough battery power to turn the engine as normal it wont start at all it just turns and turns the engine over and now have hdc inactive message on dash ....any ideas pls
3helpful
2answers
My hitachi digtal camera hdc-570ap not switching on red led blinking other buttons not responding
You probably aren't using high power Triple A batteries. Try using Duracell Ultra high power batteries instead.
3helpful
3answers
The hdc light is on on my freelander ?
Hi:
I helped a friend with this problem. HDC is hill descent control, and a common problem on some Freelanders.
It could be a simple adjustment to your throttle cable, see this link:
http://www.myfreelander.co.uk/Body/femmemprobs9.htm
1helpful
Hitachi HDC-887E wont switch on
I have the exact same problem and also do not know how to fix it. Were you able to fix the problem? If so I woulsbe keen to know how you fixed it.
Top Hitachi Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
