Price Pfister 01-31xa Shower Head, Tub Spout And Valve Logo
Posted on May 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hot watwer leaks from the hot side of the facet
Anonymous
Level 2:
Scholar:
  • Expert 81 Answers
  • Posted on May 29, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
81
Questions
Helped
61081
Points
165
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
How to change out copper piping from release valve
If the release valve referred to is the pressure release valve, then a water leak out the attached vent pipe is an indication that the valve is failing. To change the valve, the water must be allowed to cool (turn off AC power or gas) and the water level inside the tank must be lowered (drained) to below the level of the pressure relief valve. Once this is accomplished the vent pipe is unscrewed from the relief valve and the pressure relief valve is unscrewed from the water tank. A new pressure relief valve with a sealant on the threads, is then screwed and tightened into place with the outlet port facing downward. The vent pipe is attached to the new valve and the tank refilled with water. A hot water facet must be opened to allow air to exit while filling. Upon becoming full (water will begin to flow from facet), turn off the facet and restore AC power or gas, therefore allowing the water heater to heat up. When the first hot water is utilized there may be some air expelled from the facet.
Delta 18 series tub facet leaks
the possible cartridges you can replace are listed on this pdf
http://www.deltafaucet.com/media/SpecSheet/DSP-B-R18000_Rev_A.pdf
1helpful
2answers
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 • Home
1helpful
My single handle bathroom facet works in middle and cold position ,but when placed into the hot water side water just drips. How can I fix that?
It appears some scale from the water heater has the valve obstructed. Going to need disassembly to clear it.
Nov 01, 2009 • Plumbing
Ice maker won't worker - freezer too cold
Switch the line to the hot water facet and turn down thwe thermostat in the unit.
My Danze Anu Kitchen Faucet
Sounds like you have hard water.  You need to change the inside of the facet.  before doing anything make sure you CAN get the parts for you facet.   Danze are not very expencive you might just get a new facet.  If this is a hard water problem you might want to buy a moen facet with a life time warrinty.  More money but free replacement parts.
Apr 04, 2009 • Plumbing
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
1helpful
Leaking Delta bathroom facet
Is this single handle?If so, you need a allen wrench to take handle okk.But come to think about it you get the tools with the repair kit.
Mar 13, 2009 • Plumbing
Top Price Pfister Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
