I would say that your problem would be the main spring. This happens a lot of the watch is wound too often or too tightly. As this post is almost 3 years old now, I'd assume you have already found your solution.I would say that your problem would be the main spring. This happens a lot of the watch is wound too often or too tightly. As this post is almost 3 years old now, I'd assume you have already found your solution.
You can't post conmments that contain an email address.
RECOMENDATION:
Seek professional help for watch value.
In short, demand for antiques pocket watches are up the real question is what is it worth to you?
Keeping it in running condition increases its value to you and the next generation.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
If you go to the web site "www.antique-pocket-watch.com/waltham-pocket-watch.html", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
Ebay often has these for sale; one I also inherited in an 18K gold 'hunters case' (closes from and back) even though perfectly working after a retired jeweler brought it back to life, turned out to be more valuable for its case than anything else.
I've seen similar at swap meets/flea markets in plated cases for as little as $70 and still ticking.
Pull the wind knob out...it takes a firm pull on mine. You will hear it click, then you have room to pull the movement out towards the hinge. Then close when done, and push the wind handle back in.
At one oclock the lever is pulled out about 1/4" then you can set the time, when finished, push the lever back in.
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
there is no battery its a mechanical watch
