the valve and wiring can be replaced you cannot remove it altogether as it wont be able to fill up, bosch aqua stops are normally powered solenoids that also double as the water inlet valve unlike most other aqua stops
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Most of the dishwasher has a Thermal hold period in which the machine will not advance to the next cycle until the water temperature reaches a specific degree. it is possible that your aqwa sensor/or heater is bad OR as in most of the cases, the Timer relay that is responsible in turning the heater on is stuck open, in this case you need a new timer. So,Check Timer/Aqua sensor/Heater
