I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
Had the same problem, i took the batteries out and connected a normal 12volt car battery charger to each battery for 30mins. this was enough to raise the voltage for the normal charger to work
If it is only 11 months old, I suggest that you get hold of the nearest Pride service rep, and get them to look at it. It should still be under warranty. We are a Pride dealer, but we are probably a bit to far away here in New Zealand. Good luck. Neil.
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
SOURCE: Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
SOURCE: I have an Elite Traveler Plus.
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
SOURCE: battery won't hold a charge
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
My go go elite traveler plus when charging the poet light comes on but not the charge light what am I doing wrong
How do you remove batteries from go go elite traveler plus scooter
