Epson Stylus R265 InkJet Photo Printer Logo
Posted on Apr 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson R265 Printer
Horizontal colour banding across the page
  • Anonymous May 11, 2010
    What operating system are you using?
Anonymous
Level 3:
Genius:
  • Master 1,447 Answers
  • Posted on Apr 12, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1447
Questions
Helped
468018
Points
4051
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
I have an Epsos Stylus Photo R265 printer. I want to print a Word doc in b&w not colour. How do I turn the colour setting off for the printer? [email protected]
After pressing print, when you're on the print page, click "Printer Settings." You should have some color settings, one of them being black and white.
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
2answers
My Epson R265 prints all of the colours green
Sounds like colour contamination to me.
Check the carts are in the right slots.
then print until it clears the problem.
5answers
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
2answers
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
3answers
Epson r265
Check status monitor if empty or low:
Replace if empty ect:
Soak the cartridge nozzles upright in Flush Solution for 6 hours dry and retry , make up a A4 Paper colour printing page with each colour band about 1" high x 8" wide and print out 4 - 6 pages checking which colour band is poor:
Keep printing if improvement noticed:
if not
Resoak the offending cartridges and repeat:
also can
Use cleaning cartridge on offending colour slot/s then retry:
Dont use the head cleaning utility to much as it is programmed to disable your printer after a pre-set number of cleans and will have to be serviced:
[email protected]
1helpful
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
[email protected]
PRINTING PROBLEM
You printer cartridges need to be cleaned,aligned properly...printer software can do that...
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
