SOURCE: picture for portable dvd player look like a negative of a picture
Cyberhome has a private but public, and helpfull web page to assist you with a Cyberhome DVD player and repairs. Its free and I have found very helpfull in the past. Just go and explore. If you dont find your unit being spoke about, ask a question. Good Luck http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums PS Please dont forget to rate this thread.
SOURCE: Mintek DVD Portable
I had this problem. You need to reset your dvd player. To do this: For the reset, the unit should be on Wall power only, with the battery removed. You set the LINE SELECt (on the side next to the VIDEO plug) device to IN, turn the unit on, after 20 seconds switch it back to OUT.
SOURCE: Disney princess dvd player will not play any dvd!
We had the same issue. Try clicking <play>1234<play> and it should unlockk the dvd in the machine. Seems to work on my daughters. It's a parental control of come sort. HTH.
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
SOURCE: cable and Adapter 4 Disney DVD portable player
You can buy a new DISNEY D7500PDD car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for DISNEY D7500PDD portable dvd player
