The rerason for this problem is the remote wire is connected and works fine so when the power in the car is switched on the remote line tries to turn the amp on so it gets a power signal but the red light shuts of because the amp is not getting sufficient power from the direct power line from the battery. Check the power line that runs directly to the battery straight to the amp. Maybe you should rewire the power line and that should solve your problem.
Start removing wires from the amp, one by one (except for the +12V, Ground, and remote) until the amp seems to work fine. Usually, this type of issue is due to a speaker wire shorting to something it shouldn't be touching. Check the "non-amp" end of all the wiring to make sure they are solid and correct.
