Haier HRT02WNC Compact Refrigerator Logo
Posted on Apr 04, 2008
Kenmore Elite - 106.55606400 - Ice Maker is not working
My ice maker quite working a couple of months ago. After reading several of the solutions, I purchased a new motor module and installed it last night. When I put it in, it made one cycle of ice within the first hour and I figured that everything was fixed. When I checked this morning expecting a full tray of ice, it had not made any more than the one cycle. The beam is not blocked, I see no other problems. The tray is full of ice, but the motor did not turn the arm over to remove it from the tray. Here is one difference that I have noticed with the new part that I purchased:
Old Part: 260W-115V-60HZ 106 626663
New Part: 185W-115V-60HZ 106 628519
The parts look alike in every way. Do I have the wrong part? Why did it work on the first cycle and then stop?
Please help.
A
Anonymous
This is the replacement for the old one they stopped making the 260w
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Kenmore Elite fridge Ice Maker quit spitting out ice. There are ice cubes in the maker, but it wont release them to the bin
One thing you can do is clean up the condenser coils, the toe kick plate, and the area around the compressor to where the air flows better and it might start working.Other than that your ice mold thermostat inside the ice maker itself could be bad. They are not to hard to replace on modular type ice makers: themobilian_2492.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
1helpful
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fdfdfs43
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
