Si por favor algún alma caritativa me pueda ayudar, tengo una placa madre JetWay P4XFCP, P4X266E Series, es "nueva" por que la tuve guardada y es hora de que funcione, no se como conectar los cables del case a los pines de la placa madre. ON OFF LED RESET POWER SPEAKER, USB , les agradezco mucho por la ayuda que me puedan brindar. Buen dia:
You can't post conmments that contain an email address.
They connect to the JFP1 connectors on the lower right edge of the board. The power LED connects to the 2 and 4 pins, The HDD LED to the 1 and 4 pins, the reset to the 5 and 7 pins and the power switch to the 6 and 8 pins. The pins are numbered up down right to left like this.
97531
08642
Can you go to the MSI website and download the manual, looking at your motherboard usually it can be found at the bottom of the motherboard, usually the right side, also you should see small abbreviations of the connection relative to the pins they are associated to. If you need more help just ask. Thanks Rick.
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire). All other colors are positive. (The speaker wire color for negative is usually black & red is positive). Your MSI board has two separate sets of pins. JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
disconnect all and reconnct it.something jammed .may be *********** bord circuit is ground.
disconnect hdd ram then try.
to reattch one by one.
try with only smps ,mother bord and ram.
also check processor sitted correctly.
plz help
Buen dia:
