Hi- I have a 2002 Canon ZR 45 that has worked wonderfully for years. But today I was rewinding a tape when it suddenly started to make a weird noise, flashed for me to eject the tape, and then began trying to eject it. Unfortunately, it got stuck halfway-- it lifted, but won't actually release the tape. Nor will it go back down (and a big sticker does say to not press that part, so I haven't.) My guess is that the tape inside the cassette is stuck in some reels somewhere. It looks as if the back end of the cassette is open in there. I'm afraid to actually start unscrewing things without instruction.
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Try these steps: 1. Open the tape cover fully until it clicks open. 2. Turn the camcorder on to "VCR Mode." 3. With the cover still open and the camera in "VCR mode," take out the battery. 4. Put the battery back in--out should pop your tape. Although this worked for me, I then inserted and used a head cleaner tape which then became stuck as well. Tried the same trick to eject it, and it did come out after several tries. I will take it for a repair estimate before inserting any other tape.
SOURCE: Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
SOURCE: canon zr 300 won't take tape inside
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
Same exact problem.
