Question about Hotpoint RVM1325WW Microwave Oven
Clock frequently goes blank and needs to be reset
I have a Hotpoint over the stove microwave model RVM1325WW003. Its clock frequently goes blank and needs to be reset. I reset the clock and it works fine for a few days but then it happens again. No other clocks in the house loose their time so the problem is not due to power failures.
  • 909 Answers
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
Posted on May 21, 2010
SOURCE:
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Can,t turn the over the stove lighting on
Replace the bulb. If that doesn't work, the "Membrane switch" under the plastic film control panel is damaged. There is no good way to fix them. Contact hotpoint to see if they still have replacement panels available for this model. If not, either live without the light or replace the whole microwave.
Sep 24, 2011 | Hotpoint RVM1625 Microwave Oven
Oven display goes completely blank when I try to start it. After a short while, display asks to reset clock. I do this, then try to start oven and it goes blank again and does not start. Power supply is...
See this FixYa solution. even if your model number is different.
If this does not describe your problem, reply with your full model; number from the tag on or in the unit and a detailed explanation of the trouble you're having.
Sep 06, 2010 | GE XL1800 1100 Watts Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Mar 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave power level
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can download it free from GE/Hotpoint.
Please reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 11, 2008 | Hotpoint RVM1635 Microwave Oven
Hotpoint RVM1325WW Microwave Oven Logo
373 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Gerry Harvey
Gerry Harvey
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
