Pump worked fine at end of season but just opened pool and pump won't prime. 1. Noticed a leak at the bottom of the strainer housing. Would that explain the pump not priming or might there be another cause? 2. Since I will be replacing the strainer housing, I'd assume I should replace the pump as well.(I believe the pump and strainer housing are OEM and are 20 years old) 3. My original pump was an OC smith. How would I determine the type of Strainer housing? The Pump was an OC smith and a Hayward clorinator. 4. My pool is a 35-40,000 gallon with a single skimmer. What size pump should I be looking for. Thanks
Craig
CRAIG .. IF ITS A STA RITE PUMP DURA GLASS YA GET IT FIXED ! SHOULD COST ABOUT 75.00 SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY . ASK IF HE DOES FREE MOTOR TESTING
