Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
