Maytag Freezer MQU2057 Logo
A
Anonymous Posted on Dec 25, 2017
Freezer MQU2057: Maytag freezer on bottom froze up (literally frost...
Maytag freezer on bottom froze up (literally frost) and top fridge would not get cold...called repair man who came out and took of panel and defrosted with hairdryer but frozen up again !!! (after the $150 blow dry) Please helpme - i spent way too much money to have it fall apart on me only 15 months later!!!!
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Dec 31, 2017
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128358
Points
781
Your tech doesn't have the issue completely fixed. You have a defrost issue and defrosting manually is just the start to resolving your issue. You have to diagnose why it fails to defrost. You have a heater, control thermostat,frost sensor, etc. to check for a failure after defrosting it. Get someone that knows how to complete the job right!
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
5 Related Answers
Ismael Rodriguez Batista
  • 188 Answers
  • Posted on Dec 13, 2008
SOURCE: drain iced up in freezer
the draining pipe is block with something, you can melt the ice with a hear drier or hot water, then put a wire true the pipe and after that, test the pipe again.
Anonymous
  • Posted on Apr 08, 2009
SOURCE: Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Anonymous
  • 374 Answers
  • Posted on Jul 06, 2009
SOURCE: freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Anonymous
  • 1136 Answers
  • Posted on Jul 10, 2009
SOURCE: We left the freezer door open accidently for 10
Hi, Check the rear panel inside the freezer and see if it has frost building up on it. If so, shut the refrigerator off for 24 hours or remove the rear panel and defrost it with a hair dryer.
It should be ok after that ubless the evaporator fan motor has gone bad.
Please let me know if this helps or if I can assist you further.
Vic
Anonymous
  • 43501 Answers
  • Posted on Feb 04, 2010
SOURCE: My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Door was left ajar and it wiil not freeze
sounds like the freezer probably over worked the compresser pull fridge bottom cover off and look for frost or the condenser fins might be on back if you see frost on either one you need to turn it off and let the frost melt then start it up again
2helpful
Drain freezes and bottom ices up ii have thawed it cleaned the hose and it does the same thing each time
My be that the unit is not defrosting. There is a timer that turns off the freezer and turns on a heating element to melt the ice in the cooling fins. If this does not happen the fins fill with ice and ice begins to form as the water drips down under the ice. the bottom will freeze and the top will begin to warm.
2helpful
Coil in top of freezer and top shelf in freezer have very large buildup of ice, melted it out but it soon froze back over
Good day,
I assume this is a conventional freezer, not a frost free model.
That condition is caused either by a loss of refrigerant or an internal restriction in the sealed system.
Both are, I'm afraid terminal, unless the machine is under 5 years of age, in which case it would be covered by factory warranty.
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 • Freezers
1helpful
Heatman101
Lots of frost in freezer
check your seals on the door and see if any on the compartments are broken because if the door is broken to the compartment it could be that the the cold and warmth is mixing causing your freezer to frost up temp could also be to high check all
hope this help
1helpful
We left the freezer door open accidently for 10 days. returned to find bottom items still frozen, but top part of freezer, everything was warm. Model MQU2057BEW
Vic
4helpful
2answers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 • Freezers
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
