Question about LG 24 in. LDS 5811 Built-in Dishwasher
Trouble removing the macerator from a lg lds5811ww for cleaning. Want to make certain no foreign objects stopping blade.
  • 423 Answers
After removing lower rack and then the spray arm (pulling directly up and out), remove the (approximately) 12 silver screws from around the guard. Lift out to gain access to the lowest sump area.
Watch out for broken glass down there, it is sometimes almost invisible... and sharp!
Posted on May 21, 2010
  • Phil Dec 31, 2012
    After reading your post I decided to tackle the noisy whirring that had started coming from my LG dishwasher. I got all the way down to the lower sump area and found some broken glass, a little rock, and a broken drill bit. I can account for the glass and maybe even the little pebble, but the broken drill bit is a mystery. Judging from the rust on the bit, I'd say it has been there a long time. My guess is it came from the factory or from the installers that installed our DW. Anyway, the whirring is gone, so I'm glad I went in there, your post gave me the boost I needed to take this on confidently. Thanks.
  • Jeff Meyer Dec 31, 2012
    I'm happy my experience helped you out. Based on my experience, this will not be the last time you open up the lower sump area. If/When the odd, rythimic noise returns, you know what to do. Good Luck.
SOURCE:
My lg lds5811ww isn't pumping water out after its thru washing
The drain pump seems to be faulty, open the pump filter tray and make sure that the impeller is not caught up by some foreign object that is preventing it from turning. You might need to replace the pump.
May 16, 2015 | LG Washing Machines
Thermostat? LG Dishwasher Model: LDS5811WW
Hello Anonymous...
You hit on the reason ($$$$) I come here to contribute... Times are hard, money is scares... and my darling inhabitants are hurting...
Sometimes I can help not throw away a nearly perfect
(and faithful) appliance ... The ULTIMATE in recycling...
((Good for all of us... "inhabitants" (EARTH will be fine)).
((If you have ever seen our home from space...
It's a really pretty place. I'm not so worried for the place...
But there's a CERTAIN magic with these inhabitants...
If we pull together... It will be quite REWARDING)).
So...Thank you for ASKING.
I have a FREE manuals site where I start to read your
owner's manual... Better still... The Manufacturer also
prints "SERVICE MANUALS"...
several are shown... (don't go there yet)
ManualsLib Makes it easy to find manuals online
So being a MORE is BETTER GUY... I chose the one
that occupies the most memory....
and ran through the index 'til we got to trouble codes...
We are starting where your (pretty clever) sweetums found his
CODE clues... and we are going to look backwards..
To find "Thermostat"... (Found "thermistor").
Even if I am WRONG... You will now remember the secret handshake...& always know of the "MAGIC" of errors codes..
(which begin on your FREE page 36...
Although there is another "thermistor" error...
It is an over heat condition.. but it all for the entire PCB (printed control board) to be replaced
LG Dishwasher Main Control Board 6871DD1006Q
Code looks like an EE
with the top bar missing from the first "E"
(making it an inverted "F" (an important difference)...
We are going with ""HE""
HE"(symptom: water is not being heated)
Code yields...
>> HEATER ERROR... (check/replace "thermistor")
LDS5811WW (et al): >> (click here))...
LG DF6810WW Service Manual Page 36
This enables us to search on-line parts houses,
(everybody sells pretty much the same parts... $$, Services & guaranteed fits are different ... (My personal experience SEARS folks a rude, pushy, abusive but make up for all that by their higher than average prices... (I used to be a KENMORE fan))...
SEARS says.. the code is "tE"...
and further states the control board must be replaced
Now I use appliancepartspros, partselect, repairclinic (etc.)...
Sites (with VIDEOS) that respond to an internet search on
"LDS5811WW + thermister"
No "THERMISTER" parts found
Search Over 2 1 Million Appliance Parts
Sadly... Henry (SEARS) says the "thermister" is an integrated part of the HEATER... further adding "the part may be returned if it does not fix your trouble $54.03...ish
(SEARS = guaranteed fit).
Dishwasher Heating Element Part Number 5301DD1001A Sears PartsDirect
http://www.searspartsdirect.com/part-number/5301DD1001A/0022/722.html?modelNumber=LDS5811WW&categoryName=Dishwasher&brandName=LG
I am going to direct your reading to SEARs...
How to Replace Dishwasher Electronic Control Board Repair Guide Help Sears... Pictorial job description:
But do compare prices... and Happy hunting
Carnac the Magnificent
Jul 25, 2017 | LG 24 in. LD-12BW5 Free-standing...
Lg lds5811ww impeller stuck on
USE AN AUTOMOTIVE TYPE GEAR OR SPROCKET PULLING TOOL
Jul 30, 2012 | LG Dishwashers
LG DISHWASHER LDS5811WW HAS ERROR CODE LE.WHAT PART DO I NEED?
check for broken wires... if still cant find the problem take motor off and spin the shaft. if there is resistance then you need a new motor
Aug 08, 2010 | LG 24 in. LD-12BW5 Free-standing...
We have an LG lds5811ww dishwasher with IE error
check for voltage at the water valve when it should be filling Try disconnecting the Water Valve outlet from the DishWasher and run the output into a bucket if all is well with the valve then remove the door panel and inspect the wires near the bottom of the door. the wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.That tar like substance is one of the worst things they could of ever put into that machine causes the wires to break apart adn become brittle
Apr 30, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Water leaking from dishwasher lg model lds5811ww
The drain line is clean. Have you checked to make sure the the rest of the drain is clear all the way down to the main drain?. Also check the pump to make sure that it is working properly, it might be pumping water in, but it may not be wanting to pump the water out
Feb 11, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
Nov 01, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
413 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
