Carrier 38CKC036 Air Conditioner Logo
A
Anonymous Posted on May 18, 2010
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
Outside fan will not come on makes a humming noise
Dan Favata
Level 2:
Champion:
  • Expert 233 Answers
  • Posted on May 21, 2010
Dan Favata
Expert
Level 2:
Champion:
Answers
233
Questions
0
Helped
81452
Points
494
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
  • Paul Williams
    Paul Williams Oct 14, 2014
    When the fan is humming try to turn the fan with a screw driver or a pencil (Not your hand) if it starts to turn faster and faster it is the Capacitor.They are quite cheap. Check online
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
929
Points
Have the capacitor check......
2answers
Carrier 38CKC036350 condensor fan not spinning makes humming noise compressor hot fan can be turned by hand
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Carrier outside unit not starting and is very hot
Either the condenser fan is not working and it has shut down on high pressure... or the compressor is locked up and trying to run and is making the heat...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
My Carrier Home Central Air Conditioning Model Number 38CKC036 340 fan out side the house is not working it gives oout a low humming sound and fan doesnt rotate Serial Number 4698E05846 Manufacturer...
If the fan is humming and not running them it has gone bad....it will need to be replaced...not all that difficult a job...most pro's do it in less then an hour...
heatman101
Whistle noise from the air handler
Check the filter and change if dirty or restricted. Make sure the blower access panel is secured. Make sure the cooling coil is clean on the top (outside) and on the bottom (inside).
Fan on the outside unit is not running
Fan motor is dry or going bad try to lubricate it and see if that frees it up. If not you will need to get a new fan motor.
1helpful
Fan Won't Spin
Is it humming like a stuck motor or rattling, like a loose fan. If it's rattling, the fan could eith be loose on the motor or, the center hub could have broken loose.
2answers
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
The fan for my air conditioner will not turn. When we cut the system on it makes a humming sound and the light go dim for just a moment and this goes on repeatedly. No heat or air. We have a dual...
If the humming noise is coming from the attic it would indicate that the blower motor on the air handler is trying to start but the rotor is locked.
If the humming noise is coming from the outside unit and the fan runs but the compressor does not your compressor has a locked rotor.
If the blower motor is the problem the outside unit should still start as normal but you would have no cooling due to no air movement.
In ether case it sounds like you need to call a service tech to diagnose your system.
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
