What is error code 136 on a fisher & paykel IW709AU top load washer
Fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
sorry just found your posting do you still need help. error 136 is the motor stall error. please reply if you require further help.
I do please
I do please
I do please
I do please. The motor/ bearing is not noisy. the erroer appears after the 1st spin cycle in completed. but the second spin does not start.le
we stop the machine then start again at the 2nd spin, andn that works
we stop the machine then start again at the 2nd spin, and that works.
we stop the machine then start again at the 2nd spin, and that works. any ideas?
Fisher and paykel
Fisher and Paykel Intuitive top loading washer IW709AU Fault code 9 how to reset?
