Question about Apple iMac G4 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
Imac g4 wont boot up scree's just blue?
    Sergeant:
  • 243 Answers
Mac products did not cause any kind of issues but if any kind of issues facing by our customers then Contact Mac Support Phone Number. Here, we resolve some technical issues with our best team support within less time and our service cost is very cheap. 24*7 services provided by us for our users. So, call our best team of technician who gives you a reliable solution and our toll-free number is 1-833-284-2444
Website: https://www.support-number.co/mac-support/
Posted on Nov 21, 2018
    Scholar:
  • 72 Answers
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
Posted on Aug 20, 2010
SOURCE:
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: i have a IMac G4 that when i start it a folder wit...
It can not find the hard drive or the startup folder on the hard drive. Try and fix that by putting in the original boot cd/dvd and repair and choose your hard drive start up folde as boot device. If you can not your hard drive may have died.
May 16, 2010 | Apple iMac G4 Desktop
Can I connect my apollo 2250 to my old imac?
OS X drivers for the Apollo 2250 apparently exist only in 10.5 and 10.6, both of which your iMac G4 is too old to run.
If you have this printer attached to another computer on your home network, you could activate printer sharing and allow your G4 to print to it that way.
Mar 11, 2010 | Apple iMac G4 Desktop
Sims 3 won't install on my imac G4. I have Leopard 10.8 so I have the correct system requirements. When I click on install it keeps coming up Not supported on this architecture?
If you read the system requirements of Sims 3, it says that you need at least an Intel Core Duo processor, which the iMac G4 does not have. The iMac G4 has a PowerPC processor.
Jan 31, 2010 | Apple iMac G4 Desktop
Grandsons imac g4 desktop won't boot up. turns on and won't go further.
I see you have posted this twice. If you don't mind, I'm going to close this one and address the other one.
Oct 19, 2009 | Apple iMac G4 Desktop
Imac g4 lcd black screen replaced pram battery
If you can find an older SVGA monitor, try hooking it up to the port on the back of your mac. If you get video then chances are the LCD display is shot.
Sep 01, 2009 | Apple iMac G4 Desktop
Imac g4 dead
Hello, The power supply is part of the motherboard in the iMac G4, so it's hard to change it. The repair would certainly cost more than the price of your iMac. You can try to take off the small battery, and reboot it to see if it changes. To open the mac lay it down, screen on the table (on a t-shirt). Unscrew the four screws (they wont come out, so just unscrew them. Pull the screws and take off the silver plate. Then you'll have access to the inside. Good luck
Jun 12, 2009 | Apple iMac G4 Desktop
How to install a ram stick
Looks like it is pretty simple to install ram on the iMac g4. Here are screen shots from the imac manual that describes the process. (see below)
Mar 30, 2009 | Apple iMac G4 Desktop
Problem with Apple imac Power Supply
The most common problem with imac G4/800's are failing logic-boards. This will cause the mac to not power up at all giving the impression that the PSU is broken.
If however, you are indeed certain that the fault is with the power supply, they are available from many stores online
Power Supply for iMac G4 15" LCD (700 & 800 Mhz) 661-3184 614-0147
Dec 09, 2008 | Apple iMac G4 Desktop
Imac question
Try turning it on with the shift key down. This gives a safe boot. If it's going to turn on at all, it will turn on then. Also, boot it with Disc Warrior or Tech Tools and run some tests to see what is going on. I hope you find all is well, and that the repairs are just minor. Good luck.
Sep 19, 2008 | Apple iMac G4 Desktop
Apple iMac G4 Desktop Logo
402 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
tylerbell49
Level 1 Expert
Peter Dragonetti
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
