This info I picked up from a kind of hackers site & don't have the said player, so, its hearsay:
You need a region free player or to change the region code to play
region 1 [ NTSC formatted USA discs.]. To get your DVD to play
NTSC or PAL enter the following commands:
(Press SETUP)
Press "Shift"
Press "Mark"
Press "Stop"
Enter "0,0,0"
Enter "87154"
Press "Shift"
Enter the region or press Fast Forward (for multi region) ....................sodeep
You need a region free player or to change the region code to play region 1 for NTSC formatted USA discs.. To get your DV-1701 to play NTSC or PAL enter the following commands:
(Press SETUP)
Press "Shift"
Press "Mark"
Press "Stop"
Enter "0,0,0"
Enter "87154"
Press "Shift"
You need to convert your machine to an all-region player. The following hack works for Diamond Vision models 803 and 807 - there's a good chance it will work for the 809 provided they've used the same firmware for this model.
The region-free hack works as follows:
1.) Turn on the power and wait until the 'NO DISC' message appears, then press OPEN/CLOSE on the unit itself to open the door of the DVD player
2.) On the remote control, press SETUP. A menu will appear onscreen.
3.) Enter the following number sequence via remote: 1 3 8 9
4.) A different menu will appear. Your cursor should now be sitting in a box with the current region displayed. Use the UP and DOWN arrow keys on the remote control to display a specific region's numerical code, or select '0' (this is the number zero - not the letter o ... this is the region-free setting).
5.) Press ENTER and then SETUP to exit.
6.) Your DVD player will now play DVDs from all other regions. The code only has to be entered once. Powering down will not cause the Diamond Vision to lose its region-free setting. An added plus: it automatically senses PAL/NTSC signals but it will output to an NTSC tv set.
