LG Art Cool LA181CNW Split System Air Conditioner Logo
A
Anonymous Posted on May 18, 2010
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Hi i am using an lg split airconditioner. The split unit is not receiving signal from my remote control. Pls help me
Anonymous
Level 2:
Sniper:
  • Expert 81 Answers
  • Posted on Jun 28, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
81
Questions
0
Helped
145044
Points
276
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
3helpful
2answers
Error code ch 05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Lg art cool beeps but doesnt start
Indoor fan motor mechanism locked. Or indoor coil sensor defective. Rotate manually f.m. If easy to rotate, replace sensor. If not, replace bearings or motor.
4helpful
Lg split system ch 46 error? help!!!
Ch-46Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
A1,when stsrt up
Air filter is dirty. Clean and refit it.
The insiside unit is cover with ice and leaking water
The unit has a leak and is low on charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
2helpful
Nw my lg Aircon appear CH 46 how to solve this problem
1helpful
Lg muilty system midwall unit error code c1
C1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
sensor
LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
14helpful
LG dual split CH 46 display.....
We have an LG Split System with a Remote Touch Screen Control Panel. There is a message flashing "CH46". How do we fix this?
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
