I have a Sanyo DS27930 tv and the remote hasn't had the batteries in it for a while. I just put new ones in but it won't work with the tv. Is there a code to pair the remote with the tv? The manual only gives code for the other modes.
Check the remote control for any rust on the contact terminals of the dry cells.If present sratch it off and place back the cells and see if it operates.if it does not work you can easily identify the between the tv or the remote what is mulfanctioning by testing the remote for ir radiation,simply by directing the remote to a camera sensor of your mobile phone,if ir light is seen as you press the buttons then the remote is good and if not then the remote is faulty and might need technical expertise to repair.however if you see the ir light ,the problem lies with our set
