please help what will i do with this damn phoneplease help what will i do with this damn phone
AnonymousMay 05, 2008
sir my sms is not sending i had contact with my wervice provider and my messege center no is correct but still my set is not sending messages sir my sms is not sending i had contact with my wervice provider and my messege center no is correct but still my set is not sending messages
..........after i recieved a call i cannot send a message thru sms anymore. i
look at the call records and the number that called me says "withelding"..........
for sending text messages : 1.go to your message settings and check the message center number to see if it is correct 2. call to your network operator customer care 3. request the message center number... 4.note it down 5. go to message settings>message center number 6. insert the number which is noted by you and save it
You can actually delete the unnecessary SMS from your phone to make sure that the phone memory is not really full, outbox, sent items, drafts and inbox. You can also check if the message center number that you are using is the correct SMS center number assigned for your service provider, you might need replacing it with another message center numbers. You can call your service provider for the list of SMS center numbers that you can try to use. thanks for choosing www.fixya.com
You should follow this steps. * Main problem is some as changed your service center number. * This is the first thing you need to check when you can not send message from your mobile. * For this you need to call you are customer care. * There tell them that you can not send Messages. * They will ask your mobile number. * Tell them your mobile number. * They will tell you to change the message center number. * For that you need to select menu. * There select message. * Then scroll over to message settings and select it. * Then scroll over to sending profile and select. * There select SMS Center 1. * Then select message center number. * There you should change that center number. * After changing you can send message.
Kindly check the message center number from your mobile phone if its already there or you can contact your Network Service Provider to provide you the specific and correct message center number. Usually, you don't have to touch these numbers. If you suspect they are incorrect, contact your mobile service provider and ask them to send an Over The Air (OTA) message with the correct information in it.
Please be informed that the SMS Message Center Number is a phone number that acts as a gateway for transferring SMS messages between cellular devices.
From the Options pulldown menu, select Preferences.
The SMS Message Center and SMS E-mail Center number should appear. (Treo 600 note: tap on the tab that says SIM). If you do not see any numbers, it means your mobile service provider does not allow you to change these numbers. But usually you can edit these numbers and your Network Service Provider will provide you the correct and specific one.
This unit can only recieve SMS messages, it can not send. You can olny send messages through email. I had the same problem and I had to call my service provider who looked it up for me and found this out.
