That code means problem with toner sensor in developing assembly, try cleaning it out the best way u can, if that does not help you will probably need to replace toner sensor itself. (Toner Sensor FK2-0358)
Feb 6, 2013 - 10 posts - 5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Some ir-2230 have an pressure problen on right lower door. But check the pick up,feed,separation rollers, vertical path rollers,..... clean it, change it,...
canon errer e000024
