perhaps the left speaker is damaged
what i would do is load a known mp3 too the sdcard
and play it back on your unit
if its aok level wise
then the left mic has an issue
try an external input too the left mic
if it again records bad there is an issue with the input amp and alc circuit
if it records ok chances are the left electret mic has failed and will need replaced out usually these small mics have an amp built in then this output goes at line level to the input switched between line level in mic in or internal mic in as a mix....
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
Your external mic needs to have a 1/8" plug. You will need to find the "Mic" input, this is generally found behind a removable or hinged plastic or rubber panel, and usually near the A/V plug connectors. When you plug in an external mic, the camera switches over to use it rather than the built-in mic. On this camcorder, you cannot set the recording level of the external mic. The camera sets the level automatically. So it is simply a plug-and-play, or plug-and-record solution.
Using an external mic allows you to reduce self-noise and handling noise. It is generally recommended for better videos. Different microphones are likely to interact in different ways with your camera and its automatic level-setting, so you should try out different microphones if you have more than one available to you.
Putting spliiters on the input of a Mic priamp to connect to Mics to one pre is a bad idea. There are lots of techy reasons why, but the short version is "Don't Do it"
So how to solve your problem..
If you have a spare Line input you could buy a cheap external mixer, which will take the microphones and provide an appropriate level signal to your machine.
An instruction manual is available for download at www.canon.com Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s). Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
