Philips Magnavox TV comes on to channel 6 for a minute or more then switches to the channel last watched before it was last turned off. Model number is TP3284CI.
The problem probably on the corroded channel and volume switch tri to clean the switch with a contact cleaner...you can buy it on the electrical/electronic store...also check for any corossion at the system ic on yhe main board. there are two big ic on the mainboard one is the jungle ic or chroma and the other one is the system ic which is feets are directly connected to the channel/volume switches
clean the in between of the feets/terminal of the ic.and this will solve the problem
