Panasonic KX-T7630 Corded Phone Logo
Posted on May 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mailbox recieves messages but is not saving them (KX-T7630)
When my phone does not answer, calls are forwarded to the answering machine, which I can hear and leave a message, but when I check my mailbox, it says there are no new messages even though I know there should be.
Anonymous
Level 3:
  • Master 10,515 Answers
  • Posted on May 20, 2010
Anonymous
Master
Level 3:
Answers
10515
Questions
Helped
2935027
Points
31530
This sometimes happens on my phone. The only way I have found to clear this is to leave a voice-mail. Check your messages delete the test message and your system should clear itself out.
I think what happens is it gets stuck thinking there is a message. So when you clear the new message it then realizes there is no more messages. I know this works on my phone and could be the same for yours.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • 6 more comments
  • melissa_rain May 20, 2010
    I've tried leaving messages, but when I got to mailbox it still says I have 0 messages.
    Is it posible these message are being saved elsewhere?
  • Anonymous May 20, 2010
    Thanks for your response!!
    No, it cannot happen that your message are stored somewhere else.
    This is a Common Problem with these Handsets. Did you check, what i mentioned in my last comment?If not, kindly check and let me know.
    Hope i helped you.
    Thanks
    I can't do what you suggested because there is no message to clear? Like I said, I leave a message, but then when I check the mailbox, it does not register at all. It says you and no new messages, so I can't delete anything.
    "its says you *have* no new messages" that was meant to say.
    Thanks for your continual help by the way
    It seems like this is a Handset Problem. However, try to go for a Hard Reset.
    Unplug KX-T7630 for Few Minutes, say 15 minutes and then again Plug it Back.If the Problem would be resolved, it's perfect unless it needs to get Repaired.
    There have been reports for the same by many users for the same problem.
    Hope i helped you.
    Thanks
    No that didn't seem to work.
    However, I tried calling the phone from my mobile, then I picked up and transferred it to the mailbox. Then it said "Please enter your party's extention" I entered 701 for reception. Then it went to the old voicemail message and I left an answer, and it worked.
    So somehow, there does seem to be two mailboxes....
    I believe I have two mailboxes. One at 798 and one at 601. But when I try to get in the 601 mailbox it just ends up dialling into the office instead.
    Do you know how I can access this mailbox?
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
I have a Panasonic 6.0 DECT Talking ID Caller phone system. I lost my message that callers hear when the answering machine answers the phone. Somehow my granddaughter's voice has been recored and that...
Making Use of the Voice Mail Service
From your own extension
VPS* Extension No.
Mailbox
· If you have no password, you can skip the last step.
* VPS: Voice Processing System
From someone else's extension
VPS Extension No.
Mailbox No.
Mailbox Password*1 +
Listening to a Message
Password*1
KX-TVA series
Listen to Message
Deliver Message
Mailbox Management
Automated Attendant
Message Notification
Other Features
End Call
KX-TVS series
Listen to Message
Deliver Message
Check Mailbox Distribution
Automated Attendant
Mailbox Management
Other Features
End Call
VPS Extension No.
Leaving a Message
Mailbox No.
Enter the desired mailbox no.
To send the message immediately
Leave a message
(KX-TVA series)
(KX-TVS series)
Follow the guidance
To set the delivery time
May 24, 2011 • Cell Phones
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
2helpful
How to forward calls to another extension with panasonic kx-t7630
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
Record a voice message on the oanasonic KX-T7630
the panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps
Message answering
The phone has a FWD/DND button. Is it lit? Press it and read what the display says. If you don't have any destination, then you need to dial a new forward code. That would be *710x where 4 is no answer and 5 is busy no answer (you get to chose) plus the VM extension and #.
If your VM is 165 and you want to forward no answer calls, you would dial *7104165#.
Hope this helps.
Carl
I Need Help
hi sir
go to the settings>
advanced settings>
answer machine > enable.
it work's thank u. sir
Forward to voicemail
It depends on what you mean by not set up. Voicemail has specific steps to make it work and it starts with admin access to both the voice mail and phone system. If it is already set up (ie you can call 165 or whatever the VM number is), then what greeting it plays will give you an idea if what needs to be done.
If it plays a general greeting like when you call in from outside, it may be that you just need to add the mailbox for your extension. If it doesn't answer at all, then it's probalby time to call an installer.
Carl
2answers
Transfer the Call
press sp-phone enter *71029, then enter the outside number, then #, you will hear a tone that means call forwarding is activated.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
