Go to the following webpage and see pictures and discription of how to change you 3 wire dryer into a 4 wire dryer.
Please take time to rate me thumbs up
The model number of the dryer is not given and it is assumed it's a Whirlpool-made. Click on the links below then apply the instructions that are applicable to your dryer.
i see this all the time the dryer motor is simply to weak to kick in so it humms or sometime starts,a good test to do is flip the top up and push the start button and turn the drum at the same time and the motor should kick in,the dryer has no ball bearing it is on rollers,if you want you can check your local used appliance store and see if they have one or maybe ebay,your model number is inside the dryer door,so to sum it up it is the motor,let me know how you make out-mike
Did you check the link which i gave you? Please CLICK HERE All the instructions are given. Let me know if you have any other problem. Please don't forget to accept the solution no. 2 in the premium problem which you posted first.
