LG MV-1444Y Microwave Oven Logo
Posted on May 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our galaxy microwave wont heat at times if we unplug it and let it set then plug it back in it works fine
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10844405
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sjsj
Maytag microwave oven does not heat up using timer; works OK otherwise
If you wish to get some details microwave oven repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Wont heat at any setting? It was working fine until we moved it to another location.
There are many GE support forums and factory support sites.
You might check first for a fuse inside (OVEN UNPLUGGED!)
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
2helpful
Timer runs super fast, I dont think its heating at all. set for one hour, takes only a few seconds to run. Owned since 2003
I have a Maytag that did the same thing. I unplugged it for about 2 minutes, plugged it back in and it is working fine.
2helpful
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
1helpful
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
1helpful
FAN!!!
Oh, it turns out the the microwave was over heated and the fan was cooling it. The fan will automatically turn on and stay on until your microwave reaches normal temp. just unplug your microwave and let it cool off. then plug it in and everything should be just fine.
3helpful
3answers
Microwave timer going too fast
I had the same problem and found that the "demo mode" had been enabled. Turned it off and everything worked fine.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
