JBL HLS810 Main / Stereo Speaker Logo
Posted on May 20, 2010
I am looking for the tweeters for the JBL HLS810.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1154
Points
Try JBL agent for spare parts Speakerworks.com.au Sydney
Have 2 jbl 615 get good base and sub but neither tweeter playing
You will need to determine if it's the amplifiers or the tweeter themselves that are not working. If you open up the cabinets and check each tweeter with an ohm meter for continuity it will show if the tweeters are working, in which case the amp is the problem. if the meter shows that the tweeters are blown, you should still hook up another tweeter or speaker to the horn amp to see if it's blown and therefor took out the tweeters.
If any of this sounds complicated, you'd be best off taking the cabinets to the repair shop.
2helpful
2answers
The tweeters are not working
The crossover caps may have failed, or the tweeters themselves burned out. Using a small 1.5 volt cell touched across the tweeter leads should produce a sound. If not- they are burned out.
The tweeters on my JBL Creature speakers has been damaged ,,do you think it can be fix?
Send them back to manufacturer to fix they will more then likely have to replace the tweeters
I installed a brand new tweeter in my JBL EON 15 G2 & the new tweeter blew. What else could be the problem?
These are "powered" speakers and any little bit
of distortion can be amplified enough to "blow" it!
Also the amp could be "shorted"! Have your JBL
dealer test it!!!
The woofer doesnt work think its blown is it fixable
First, unplug the stereo speaker then open the back. you see the 2 wires attached to the woofer then test it by multi tester. if it moved it means its okay. check the wires for the loosen speakers. solder it and test it.
Jbl e80 no sound coming from tweeter
Sound like the tweeter is blown, take to local jbl agent for service.
2helpful
No sound out of JBL LSR25P speakers attached to keyboard
problem could be in wiring, fuse, crossover or the components can be damaged. the original JBL tweeter and 5.25" speaker are no longer available so replacement options would be the only alternative.
[email protected]
Eon 15-g2 upper part of my jbl is getting hot
The tweeter is not the problem. The Eons use the vents below the tweeter to cool the amp and woofer. Sounds to me like you have a power supply problem in the amp, possibly a bad capacitor or diode. You have to check the amp for proper operation.
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
