JVC GZ-MG130U Camcorder Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When playing our camcorder, the volume is turned all the way up but we can't hear anything. How can we hear what we recorded?
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on May 19, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1183276
Points
12747
My first concern would be regarding the actual working of the microphone on this unit. If the sound is so muted that the volume has to be at maximum then the microphone is probably the real culprit. Try using an external microphone and running a short test film.
Download the faulty video to your PC and see if it actually plays properly through Winamp or whatever you have to view video.
Please rate my help++++Thanks for using FIXYA
I have very low sound on my jvc gz-ms120au when playing back a recording
I'm sorry to know that the videos are playing back with low volume. I'll be glad to assist you with this. Make sure that the Camcorder is used with a fully charged battery.
Increase the volume of the Camcorder using the Volume + - buttons and check if it increase or decrease. You can also try connecting the Camcorder to the Computer or to the TV and check if the transferred videos are playing with normal volume.
There are no settings to be done in the Camcorder to increase the recording volume level.
You can also backup the files, format the memory and capture a sample video recording and check if it helps.
This should resolve the issue.
Thanks for contacting FixYa.
Jun 27, 2011 • Cameras
No sound on playback
Try playing any other recorded disc in the Camcorder to check you're able to hear sound from it.
Next, press and hold the Reset button on the Camcorder for 30 seconds then turn it off then back ON.
Then, try playing the disc in the Camcorder.
Good luck!!!!!!!!!!!!!!!!!!!!!!!!
When recording it shows that it is recording but we can't see anything. If we play back what we think we might have recorded we can only hear the sound but not see anything.
Follow the steps below to troubleshoot this issue.
IMPORTANT: If additional model-specific instructions are needed to perform any of the steps below, refer to the operating instructions of the camcorder. The instruction manual is available in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Ensure a fully-charged battery is inserted or connect the AC power adapter.
  2. Turn the camera on to the VTR or PLAYBACK mode.
  3. Insert a cassette tape with recorded video into the camcorder.
  4. Ensure the cassette tape is rewound to the beginning of the video recording.
  5. Begin playing the cassette tape.
  6. If your camcorder has an LCD screen, try adjusting the brightness or contrast.
  7. If there is still no picture on the LCD or viewfinder, reset the camcorder to factory specifications
Audio recording not very loud in play back
You may have a tape alignment issue, but, before you try anything rash, have the "control head assembly" cleaned. If you're not squeamish about opening this, you can then load a tape and look to see if the very top edge of the tape is "curled" over anywhere from .5" or greater. If this is the case, you'll need to fix what's causing that before you can do anything else....accordianman
RECORD VOULUME
put the camera into manual mode from there get into the menu options and adjust the recording volume level.
No audio during playback
On my handycam you have to hit the Volume + button while playing back. Everytime you playback it starts volume at zero and you have to volume up to hear anytime you playback.
Noise in the sound while recording
does it sound like you have stuck your head out of the window of a moving car if so then the speaker is blown it happens sometimes, worst case sometimes its the main pcb as well.
1helpful
2answers
Recording
I had the same problem but now that I took all apart and reconnected the mic it works perfectly
Audio volume
Unfortunately, connecting an external mic is not an option that was engineered into this model camcorder. Likewise the speaker and small amplifier for audio playback is simply what it is. You should be able to adequately hear normally recorded levels. If not, maybe there is a problem with the internal condensor mics or the playback speaker. If you are unable to obtain a resonable level using A/V cables to a TV, then something could be wrong. I have not seen problems with this model regarding sound, but anything can happen. Good luck, ms
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
