Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clear error code c 3421 on konica bizhub c253
Ben
Level 2:
  • Expert 108 Answers
  • Posted on May 19, 2010
Ben
Expert
Level 2:
Answers
108
Questions
0
Helped
89386
Points
277
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
  • riandi
    riandi Oct 28, 2019
    i have had trying your guide how to rest it but it's doesn't worked...can you show me the link for video about it
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I have an error code C5370, which will not clear. The Service rep is stumped at this point. Originally, we had a glob of toner that gummed up the works, and he took the entire machine apart to find t
See the link below: looks like a cooling fan error code and the fan needs repalcement. You got a GOOD REP oh yeah...
http://www.copytechnet.com/forums/konica-minolta/27391-bizhub-c253-error-c-5370-a.html
1helpful
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Bizhub c203 with c3421 error code
http://www.oasq.com/how-to-clear-error-code-c-3421-on-konica-bi-thread-733519-1-1.html
2helpful
2answers
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
1helpful
2helpful
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
2helpful
What is error c-2527 of konica minolta bizhub c253
sorry, cannot find that error code in SM. Are u sure is it correct code?
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
