It says just Network lock only,You need to enter the Code if it locked Network mean.You can get the Unlock code at here
http://www.superunlockcodes.com/sidekick-lx-2009/rs12wp9/ and Unlock it,get the Unlocking Instructions below to unlock it step by step.
Sidekick LX 2009 Unlocking Instructions
Warning :
Do not enter any wrong unlock codes on your Sidekick LX 2009 mobile
phones. If you enter over a certain amount of wrong unlock codes on your
Sidekick LX 2009 mobile phone, your phone may get hard locked and
sometimes become unusable.
1. Switch ON your Sidekick LX 2009 with a
Not ACCEPTED SIM Card.
2. If your Sidekick LX 2009 asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick LX 2009 will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick LX 2009 is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick LX 2009 is locked to.
Each
Sidekick LX 2009 mobile phone has an unique unlock code. You can buy
the unique unlock code for your Sidekick LX 2009 mobile phone using the
form above.
I am not sure if this is for the correct sidekick but it should work: 1. Press the Menu button. 2. Scroll to and select
Settings 3. Scroll to and select System
Info 4. Press the Menu, Shift
and X keys simultaneously. 5. Select Erase
to erase the flash settings. 6. At the System Info
screen, press the Menu, Shift and R
keys simultaneously. 7. Select Erase to erase the
Sign-In information. 8. Insert a paper clip in the reset hole
while holding down the Power button. www.usedcellphoneshop.com
