Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
type *#06# for your imei number, there is one way to breach the security codes is my Resetting the entire phone, try reset codes from http://www.unlock-free.com/
try this code 12345. If you didn't changed it Because 12345 it's the default code that the Nokia Company has provided.
And regarding your IMEI *#06# can view if your code is access fakharang.
Thanks for using FixYa
format ur mobile phone it way go to security settings and select restore factory settings. when it want code then give 12345. in the way if not success then plz reinstall ur phone application,
see budy there is no problem related to master reset it is a keypad problem, what u can do is u can go to vendor and ask to try to check the keypad is there any fault in that, i am sure abt that,
