Question about Janome MC 4400 Computerized Sewing Machine
My machine is missing stitches. on the zigzag stitch it will sew zig zag for aboout 5 stitches and miss 5 stitches.
    New Friend:
MY JANOME 4400 IS SKIPPING STITCHES, ITJUST STARTED DOING THIS, HELP!!!!
Posted on Sep 18, 2012
6ya staff
SOURCE:
Paul Moffat
  • 1027 Answers
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
Ruth Peck
  • 69 Answers
SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Posted on Feb 12, 2009
ken dourof
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
Anonymous
  • 55 Answers
SOURCE: bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Posted on Jul 27, 2009
ken dourof
  • 980 Answers
SOURCE: how do you set the zig zag stitch on a Jones
Change the needle first it may be slightly bent, if you are sewing on fabric that creates static you will need a special needle, failing that you may need to retime the machine.
Posted on Sep 11, 2009
Do i need cam to do zigzag stitch on Kenmore 158.17600
This video will probably be handy, although not quite your model, it should be very close. Generally, your machine should be able to do straight & zig-zag stitch without cams. Cams were usually for decorative stitches.
Kenmore 158 17550 Sewing Machine Tutorial
Parts: https://www.sewingpartsonline.com/kenmore-158-17600-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=64
Manual: Kenmore 158 manuals 3
Jul 20, 2018 | Kenmore Sewing Machines
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
White 1521 only zig zag even on straight setting had it cleaned but still only zig zag zig zag on all setting how or can it be fix?
I don't think it needs to be fixed. If you want to zigzag, there are two setting you need to do. One is the stitch length and the other is the stitch width. When you sew a straight stitch, the width is 0. If you want it to zigzag, make the width wider (usually 1, 2, 3, 4, or sometimes 5). I've looked at the manual for this machine and page 21 has some info. There's probably more if you read further. If you don't have a copy, go to singer.com. They have tons of manuals for many brand of machines. Click on the support button and go from there.
Dec 02, 2017 | Sewing Machines
Machine not picking up a zig zag stitch
it's possible that the cam that makes the zigzag stitch could be worn or damaged, it would probably be a good idea to have the machine checked.
Feb 23, 2014 | Brother XL-5700 Mechanical Sewing Machine
I'm sewing a zig zag stitch and the underside is a perfect zig zag and the upper side looks like it should be the underside....how can I fix this so that the beautiful zig zag is on the top?
FIRST > Make sure your bobbin case is threaded correctly...
NEXT
For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
Jan 15, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
MC4400 skips on the zig zag stitch when sewing
You must buse an anti static needle otherwise yoiu will miss stitches.
Jul 13, 2010 | Janome Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
1,048 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
