Is there a better/ more efficient way to scan a large document (200+ pages) so it doesn't take up so much memory and lock up the machine for 10 minutes?
Yes in your scan setting select scan type in there you will see compact pdf.That will make a 10 meg file be 900k even if it is color.
1twig
Memory full on and cannot scan items Help
Unfortunately anything on your original that is not white (paper) will take up memory. You could try using a different file type. PDF and Compact PDF I believe are the smallest. Using TIFF or JPEG will make the files huge.Also if all your documents are B/W make sure you don't have color or auto color selected under you scan settings.
