Sears carries manuals for most of their machines (usually for free). The manual is invaluable for using your machine, including threading instructions.
Place both the bobbin case and the bobbin on the table in front of you. Have the open side of the bobbin case facing up and the bobbin with the thread of the bobbin unwinding clockwise. Drop the bobbin in the bobbin case. Pull the thread tail up through the notch in the bobbin case and then to the left under the thin metal plate until the thread appears to be coming out through the hole in the side of the bobbin case. (When you pull the bobbin thread, the bobbin should turn clockwise in the bobbin case.)
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
try these suggestions Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine.
Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
How to thread this kenmore
