Galaxy Radios DX-33HML 40-Channels Base CB Radio Logo
A
Anonymous Posted on May 17, 2010
Radio come on but do not recive or put out no sound
Anonymous
Level 1:
  • Contributor 64 Answers
  • Posted on Sep 12, 2010
Anonymous
Contributor
Level 1:
Answers
64
Questions
0
Helped
15981
Points
77
There is not enough information here to solve your problem but I can give you some places to start. Check your Mic something as simple as a broken ground wire could cause this. A quick check to see if the s meter is moving with signals could tell you if you have signal coming into the radio. Try another mic do some further diagnostics or seek professional help. There should be a CB shop around near you if not look for one at a truck stop.
Hi have a cobra model number HH125EU it is stuck on chanle 9will not transmit or recive
It sounds like a synthesiser fault... might require a chip replacement.
148gtl has no recive sound through speaker or ext speaker
Plug your external speaker up in your PA jack key up...do you hear anything...if no you IC Chip is put in your radio.Take to shop. If you do you might have a bad soilder around IC chip on board.
2answers
Cant recive from than 100 ft away new antennae still nothing
I suggest that the radio needs to be realigned to receive. If the radio has been dropped or banged in any manner this could have caused your problem.
No cb channels no audio no recive
If you have no channel display or CB operation, it sounds like a blown voltage regulator that supplies power to the CB PLL circuit.
1helpful
Loss user manual for Pro-82 Scanner Reciver.
Hi - You can download the manual from the link below:
Radio Shack Pro-82
Please update the question & let us know if the information given was useful to you - Good Luck!
2answers
I have no reciving in a cobra 29 ltd chrome
Bad switch. It's that simple. The factory switches are crimp together junk. You may be able to use a pair of needle nosed pliers to softly squeeze the case of the switch together to correct the poor contact in side of the switch, but, if it gets a lot of use you may need to replace it altogether. Or try adjusting
Thanks!
Dodgem
http://dodgem250.angelfire.com
Cobra 142 base
I don't know this radio individually, but heres the common thing that happens:
Sounds to me like the 8 volt regulator chip has blown after overvoltage. I expect the power supply has gone too, putting 18+ volts into the radio.
Repair the power supply. (Check its 13-13.8 Volts).
Then check the regulator (7808) is putting out anything, should be middle pin ground then 13V one side and 8V the other, if nothing, its blown. Replace it if gone.
Hopefully thats all thats gone and it should work again.
Sound cutting out
sub should work as long as u don't have the reciver on digital it should still work ur mains and the sub but no sound from the rears, the radio cuting out could because bye a resister failing it might not have burnt out yet but it is not working proprely if it only happens when the radios is on try to see if local stations come in clear with no antena . but if it happens when the reciver is on tv or another input take to ur closest repair shop to be fix or u might fry the mother board happen to one oif my old recivers.
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
