Brother printer hl2170w drum light
Drum light ended need to be replace drum.
Steps to Connect Brother HL2170w Printer to WiFi Connection:Step 1. Using a Network Cable (or via Wireless Setup Wizard) Before arranging your printer's remote settings, you ought to be clear with the remote switch or AP's system security settings. Record for further utilize these setups.
System Name (SSID: Service Set ID, ESSID: Extended Service Set ID) Network Key (Password, Security Key or Encryption Key, and so forth.) This detail can be found in the switch gadget documentation or at the back.
Stage 1: Set the settings. Contingent upon your OS, the screens may change.
Stage 2: Connect to your Brother gadget one finish of your AC power string and to the AC power source one end.
Stage 3: Switch on the machine of your sibling.
Stage 4: Turn on your chairman PC framework.
Stage 5: Insert in your CD-ROM drive the given CD-ROM.
For More Information call us at +1-888-633-7151 or visit us Connect Brother HL2170w Printer to WiFi
https://www.brotherprintersupport247.com/blog/how-to-connect-brother-hl2170w-printer-to-wifi
When the light comes on, you will need to replace the drum. The drum is the part in where the toner is attached to. You would need to remove the toner first from it's base.
Hi There,
The Drum LED and the Error LED alternates turning on and off.
Meaning of LED Indication
Drum error:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Please click on YES if this helps,
Thanks,
Vikroks
